Upated to 5.0 over the weekend. I have haptic feedback on the Home/return/app row at the bottom of the screen. I don't have any feedback when opening any app or sending a text. The motor obviuosly works, because it works on the home row keys. I tried the factory/google keyboard and SlideIT keyboards, no luck with either. I have messed with sound, display, and power settings with no luck. This is the only thing that is really bugging me after the lollipop update. The battery life sucked at first, but killing the emai app after opening/synching/checking fixed that. If anyone can help with the haptic issue, it would be very appreciated!
What if you repair your phone with PCC and check again
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Open the messaging app > menu > settings > and check for this feature, same for the keyboard settings.
It's selected under Sound. Nothing under the messasges/SMS menu... The screen capture from the general settings shows it is selected.
Settings > languages & keyboard > xperia keyboard > sound & vibration
Good to go om keyboard input. I appreciate that. Any way to get it to work when touching a contact/app/email etc...?
Settings > sound & notifications > other sounds > vibrate on touch
That one is not fixing it. Even when I select it in the settings menu, it just clicks with no feedback.
Restart the phone and check again
Restart did not fix. Still has home row vibrate and keyboard vibrate, just no feedback on anything else.
