- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My device is Xperia Z Ultra C6802 with the latest android 4.4.4 and firmware version 14.4.A.0.108
How can i fix this issue?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you tried the FM Radio with different headset connected?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When i start fm radio app it just crash and says unfortunately, fm radio has stopped.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm also facing similar problem. by FM radio is starting fine but no sound output. Not even in the speaker mode. I tried the same headphone in another mobile and just worked fine for FM Radio there.
What can be the problem? Is it a software bug or an hardware one?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same here.
I know the radio's picking up the signal OK, as the visualisation changes in time to the received programme (checked against another FM radio) , but there's no audio on headphones or speaker. Reception is very good at my location in general, and I've tried a variety of headsets, but nothing produces any actual audio.
I've tried disabling the radio in the Apps menu, clearing all data and then re-enabling, but it makes no difference. It did work before, and the failure may be tied to the latest Android update, but I can't say for sure.
Model number C6903, Android version 5.0.2.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I was also facing same issue.
the solution is Turn off google now setting -> detect voice from every screen.
Radio will work properly.
Thanks.
Santosh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
in android 5.1.1 it 's presumably relate to update your FM radio .for return to factory version your Radio you can go to:
Settings> About Phone> Diagnostics>Go to Application Incidents> go to FM radio > uninstall last update for your FM radio> then restart...
after restart maybe your problem with radio solved!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks man, worked for me after seeing language to English (US)
