hey guys i want to know if force shutdown (press and hold power button along with the volume up key) may damage the phone cuz i did it around 4 times
Nope it doesn't. It's the same as pulling out your physical battery. All it does is cutt-off power from the battery.
ok thank u mate one more question can u tell tell me if it's safe or not? http://talk.sonymobile.com/thread/132764?tstart=0 cuz i do the same thing i open screen lock when the phone is underwater should i stop it?
it is safe. the water resistance applies to all buttons as well on the Z as well. even the speakers. basically, the phone as a whole unit.
u awesome man thank u
