@Tattoofreak wrote:
No its not it's if you leave your phone unlocked then put it on charge the screen stays on it doesn't go into lock in same as when you press the button to lock your screen
You haven't accidently activated Developer mode and turned on the Screen stays on while charging option "Stay awake" have you?
Go to settings-display and see if daydream is enabled.
Before you boot in safe mode, if you go to settings and scroll down, do you have developer options there? Above about phone. If that is not enabled, we can try safe mode.
