After latest upgrade to Android 5.1.1 unlock using NFC tag (nfcring, tag etc) doesn't work. I successfully setup my trusted devices in Settings -> Security -> Smart Lock, but when I lock the phone there is no reaction when I try to use the NFC tag to unlock the phone. When the phone is unlocked, it detects NFC tag just fine. Also other means of unlock (like bluetooth device in trusted devices) works just fine.
Unlock using NFC tag used to work with previous update of Android (5.0) just fine on the same phone. To me this seems as a bug in the Sony provided system image...
After upgrade to the new version of official Sony image (14.6.A.1.216) the problem diappeared. Thanks a lot guys!
I can't find my NFC tags to test that for you, I'll try to find them and tell you how it goes. I'll try also to escalate this.
Hi @nax,
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Model number:
IMEI nr:
Build number:
Thanks!
