I have Volvo V40 and when I step in my car with my bluetooth enabled already, I see on my Z3 Bluetooth connect sand then disconnect. This repeats all the time. When I then disable bluetooth, wait a while and enable bluetooth again, the problem is gone. I don't know for sure, but what I have see on my car's phone menu, although I get these disconnects on my phone , the disconnects are not noticed by my car. But again, I didn't look into that yet. Do you have similar problems?
Same problem here with a heart rate monitor. keeps disconecting all the time.
Z3 compact with 4.4.4
I have a Volvo C70, Xperia Z3 Dual, Android 5.0.2
When I turn on the bluetooth and have the BT Selected in the car, the music starts automatically... after 1 or 2 minutes, the phone is disconnected (music stops). On the phone, the Volvo is disconnected in bluetooth settings.. If I disable the bluetooth and re-enable it on the phone, it works for 1 or 2 minutes and stops again.
I tried to manually connect the phone to the car in bluetooth settings after a disconnection... in this case I could listen to music for 30 minutes (until I arrive to destination).
I think there is an issue with automatic connect and then automatic disconnect for unknown reason.. This is very bad beahaviour...
Just to tell you that this is not due to the Car etc... I have an HTC One X (4.2.2) and LG G2 (4.4.4) without any issue for months... I have this only with Z3 Dual with 5.0.2.
A fix would be appreciated...
Hi guys yesterday I've bought my z3. I've connected it to my BMW X3 bluetooth handsfree system and used it several timers ... not so smooth like I wanted, but still working ... Later I've received software update notificationq updated and today I cannot connect to the car's bluetooth. Tryed with another smartphone - car bluetooth working correct! Do you have some solution fot this issue!?
hi im also having the same issue with this it says i should reconnect wiht the lifelog app but its almost 10months now that im not using this app and this is the only time it keeps me reminding to reconnect with this app..its annoying and keeps on vibrating using my battery..
by the way im using sony xperia 2 android version is 5.0.2 lollipop
