That shows you that the problem it's a third party app, an app that was not included with the phone.
hi
i have sony xperia z1, i updated it to 14.5.a.0.270
after that the battery very bad, for example, it has 50% and after i use it for 20 min or less than it , suddenly it is 1 % and the phone turn off. i put it in charger it give me that has 1% and after 5 min i turn on my phone , it give that there are 60 %.
i try to reinstall by sony pc companion and make reset factory but still same problem
help me plzzz
this is the problem ,suddenly low battery from 30 % to 0% and it turn off . i turn on after 10 sec and press power button + volum button and it increas to 14 %
Pleas help me, still same problem
I reinstall by pc compenation and rest factory
Hi there,
I had the exact same problem on my Z1.
I changed battery few days ago, Obviously things are going better. I can get through a day with a full charge.
But the problem is not totally sorted out.
Yet, I still notice a strange behavior when charging it. Phone will go to full charge 100%.
And then if I Hard reset, I find the gauge says about 92/95.
I put it on charge again and it reaches 100% within 3 minutes. That's the first point.
Second one, is that I still have this ********** sudden drops if the battery gauge.
It goes from 95 to 85. then from 70 to 60 and so on...
This is such a shame for a phone I bought 500 euros !!!
If Sony just can't make an accurate battery circuitry and gauge, just say it clearly ! We, as customers, should know !
I think this new battery will just die too early (like the old one, after on year) because of these issues !
Please moderators, suggest how to force calibration or other tricks that could make the gauge accurate again like it used to be.
