4.2.2 has a lot of bugs need an imediate update as soon as posiible listed below
1.camera has lost its clarity and pixel rate need to rectify this
2.walkman has improved in bass and sound quality but the volume is too slow that it cant be heard in outdoors
3.album is failing to load pics whille opening for first time
4.notifications sounds are starting to ring as if they are strucked and resumed
5.lock screen left portion there is nothing use of it as widgets are not going to help anyone instead a music app or customized app otion should have been given
6.while playing games or other apps the haptic feed back should be disbaled automatically like it hapnds in video player and when touched at botoom it shoudl come so that we can enjoy the complete screen xperience
7.battery was gone poor i m wondering the minute i m remove charging it comes to 98% without any usage and slowly comes down to drain with out any usage
8.the transitions are not as smooth as before
9.when we get a call it is taking some time to respond to answer a call and even to complete a call the end function is also consuming some time to finish too poor
10.some solutions shoudl atleast come upnow for heating issues because while talking in phone for just a minute the phone start to heat as a result it is unable to talk as ear is also geeting hot rays.....it is ok during games and videos as we just hold it but while talking it is placed on a ear so ear gets damaged and it is not posbile to talk fir a long tym
once these problems are solved there is no dout this will the best of sony ....til then having these many complaints we cannot call it as best of sony
all points very much true..one more thing beside these is that while playing games after some it starts to lag alot..which results in a shitty game playin experience..very much disappionting..do somthing fast Sony.!! ASAP
add on,
1 - why remove screenshot in power button option and require us to use power+vol down?
for me power button option with screenshot is more convenient (and yes i aware about the clip manager but not convenient as you cannot clip-screenshot your notification bar stuff).
2- facing some glitches when scrolling down the notifaction bars (some lag/delays), and/or the notification bar stuck in the middle without going all way down (anyone facing this?), and/or some apps notifications overlap with another app's notifaciton while scroll down notification bar to see app's notification (for now only happen once) .
Until then i m using the 4.1.2 with 434 firmware by far the most stable and bug free firmware rom
Sony wake up and give us proper 4.2.2 firmware and not the crappy with the last one:smileywink:
It s total unacceptable instead upgrade to have downgrade in user experience with the 4.2.2 and issue arise from zero when everything working much better with previous version of Android.
lolz try the 253 update the last one in 4.1.2 i loved it that was the best in batery or gaming or appearence or wat eva that looked and gived the best performance
no ya my navigation bar is working perfect no issue with that and ya screen shot buton has been removed and when i was trying with power and volume button some times its nt responding but some times it dooes
if sony is listening to us please check out problems and solve this major issues please sony we purchased the costliest phone in sony solve our problem atleast to this high end mobile please....rply to this post sony please\
And Sony... since the navigation and status bars are now "transparent", can't you just make the top one completely transparent OR AT LEAST GIVE US AN OPTION OF TRANSPARENT/BLACK/GRAY/OTHER COLORS? Black wallpapers look bad again now, since the top bar is no longer black, but gray becaues of the transparency (why?), like it was out of the box before the last update.
this could also be given as a customized option
