I just got notice of the android P update (52.0.A.3.27) from my carrier on Bell for my H8276 model. After the download and restart, my phone would bootloop 5-6 times and would roll back the update to the existing Oreo that is on the phone. The phone says the phone failed to update. Screenshot attached.
Any idea what's going on and is this happening to other Canadian XZ2's out there?
Timeline of events
2018/10/16 (eastern timezone)
11:30PM - Performed Android P (52.0.A.3.27) from my Canadian carrier Bell
11:50PM - Flash complete and device asks to restart
11:55PM - During boot, the Sony logo flashes multiple times about 5-6 seconds inbetween each other and then boots successfully but back into its previous update (Android O)
2018/10/17
12:25AM - Started Xperia companion and was prompted to update (software version after update is 2.2.5.0)
12:40AM - Software repair completed with Xperia Companion and the phone will not boot at all. Behavior same as before the Sony logo displays multiple times between 5-6 increments except this time the phone displays "Your device is corrupt. It can't be trusted and will not boot. Your device will be powered off in 5 seconds" and the device will shut off.
1:00AM - Re-performed the software repair again on xperia companion and the same behavior is observed. The phone will never boot into system and displays the device is corrupt.
9:35AM - Performed re-flash to an old FTF (51.1.A.11.26_R12A) and the phone works and phone is back in service. *Software update notification is constantly displayed, and going through the same update via phone has the same behavior as the very beginning of this thread.
12:00PM - Called Bell Mobility to explain the situation and they asked me to call Sony for support
12:10PM - Used the online chat at Sony support and the agent was adamant that I try Software repair again, but with the device off...... (I think everyone on here already know it does the same thing whether the phone is on or off, it triggers the phone to be on flash mode.) But anyway, I did it and the same results.
12:36PM - As of now I'm without support from my Bell or Sony. Next step is call Sony again.
1:30PM - I found a very interesting behavior. If the Sim Tray is removed the phone restarts and boots into Android P without a problem. But if I have the sim tray plugged in, with or without a SIM the bootloop happens. Please note: if I reflash back to Android O, the device boots without a problem with and/or without SIM in. Looks like a compatibility issue between my carrier/model(H8276) & the Sony Android P software 52.0.A.3.27.
2018/10/21
As advised by Sony phone support (they were excellent, @john- thanks for the help) I sent the phone in to the local service centre to have the software looked at.
2018/10/30
Got an email from the local service centre saying that my phone had water damage and "deemed beyond economic repair". I wonder if they even looked at the actual issue that the phone was facing and not look for hardware problems to write off my device. My device works perfectly fine in Oreo.
I've re-escalated the case to Sony phone support, because in the end, I want the phone to be able to get security updates as that is important to me.
I got my old Samsung Note 4 to take a pic of the corrupt message. Here it is.
Do you reckon the h8276 model was left out of this official release by mistake (since it was not permitted on the android P beta) and someone forgot to re-enable it before pushing this rollout? If so, I hope Bell/Sony is listening and quickly rollback this OTA update for h8276 on US, Canadian or actually global carriers or there will be more bricked phones so long as this update remains as the latest update for people formating/repairing their Canadian Xz2's.
Just to make sure, you didn't unlock you bootloader before? Also I assume the 2nd repair process was done without success?
Are you running the latest version of the Xperia Companion?
No, bootloader was never unlocked and the second and third repair attempts failed as well.
Xperia companion had an update available when I launched it (I haven't used it in awhile) So when I used it for this Xz2 repair it is the latest.
EDIT: screen cap of the version here. Its the latest as of today. Version 2.2.5.0
It's the time to contact support then, as you said either Sony or Bell. Your other option is to flash an older firmware using Flashtool and a downloaded FTF file.
I just noticed that it said Copyright 2008-2016 in one of the first pictures, and that indicated that the program perhaps was not the latest.
For a last test, I would download from SonyMobile and install Xperia Companion on another computer (that never have had the software installed before) and try again to do a software repair.
Ok I will give it another go this morning (EDIT: still does not work after redoing the flash with a different PC) and will call support when their lines are open.
I just want to still be able to get security updates going forward.
Any other Canadian Xz2 users on here experiencing the same issue?
I found a very interesting behavior. If the Sim Tray is removed the phone restarts and boots into Android P without a problem. But if I have the sim tray plugged in, with or without a SIM the bootloop happens. Please note: if I reflash back to Android O, the device boots without a problem with and/or without SIM in. Looks like a compatibility issue between my carrier & the android P software.
I have updated my original thread with timeline of events and summary of troubleshooting steps taken and observations.
Glad you got some progress.
You say that with Pie installed, the bootloop happens with or without a SIM as long as the simtray is in?
-That should point to a problem with the tray itself or connector, not carrier/SIM?
Is there a memorycard in the same tray?
@Runej
You missed that the tray works in Android O. Tray only affects Android P.
No SD card in all scenarios
