I just got notice of the android P update (52.0.A.3.27) from my carrier on Bell for my H8276 model. After the download and restart, my phone would bootloop 5-6 times and would roll back the update to the existing Oreo that is on the phone. The phone says the phone failed to update. Screenshot attached.
Any idea what's going on and is this happening to other Canadian XZ2's out there?
Timeline of events
2018/10/16 (eastern timezone)
11:30PM - Performed Android P (52.0.A.3.27) from my Canadian carrier Bell
11:50PM - Flash complete and device asks to restart
11:55PM - During boot, the Sony logo flashes multiple times about 5-6 seconds inbetween each other and then boots successfully but back into its previous update (Android O)
2018/10/17
12:25AM - Started Xperia companion and was prompted to update (software version after update is 2.2.5.0)
12:40AM - Software repair completed with Xperia Companion and the phone will not boot at all. Behavior same as before the Sony logo displays multiple times between 5-6 increments except this time the phone displays "Your device is corrupt. It can't be trusted and will not boot. Your device will be powered off in 5 seconds" and the device will shut off.
1:00AM - Re-performed the software repair again on xperia companion and the same behavior is observed. The phone will never boot into system and displays the device is corrupt.
9:35AM - Performed re-flash to an old FTF (51.1.A.11.26_R12A) and the phone works and phone is back in service. *Software update notification is constantly displayed, and going through the same update via phone has the same behavior as the very beginning of this thread.
12:00PM - Called Bell Mobility to explain the situation and they asked me to call Sony for support
12:10PM - Used the online chat at Sony support and the agent was adamant that I try Software repair again, but with the device off...... (I think everyone on here already know it does the same thing whether the phone is on or off, it triggers the phone to be on flash mode.) But anyway, I did it and the same results.
12:36PM - As of now I'm without support from my Bell or Sony. Next step is call Sony again.
1:30PM - I found a very interesting behavior. If the Sim Tray is removed the phone restarts and boots into Android P without a problem. But if I have the sim tray plugged in, with or without a SIM the bootloop happens. Please note: if I reflash back to Android O, the device boots without a problem with and/or without SIM in. Looks like a compatibility issue between my carrier/model(H8276) & the Sony Android P software 52.0.A.3.27.
2018/10/21
As advised by Sony phone support (they were excellent, @john- thanks for the help) I sent the phone in to the local service centre to have the software looked at.
2018/10/30
Got an email from the local service centre saying that my phone had water damage and "deemed beyond economic repair". I wonder if they even looked at the actual issue that the phone was facing and not look for hardware problems to write off my device. My device works perfectly fine in Oreo.
I've re-escalated the case to Sony phone support, because in the end, I want the phone to be able to get security updates as that is important to me.
What I'd do in your case is to back up all the data stored in the internal storage then perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory.
The phone works fine now, but I'll give that a try and report back. thanks for the feedback.
I'm in Canada, and this H8276 model is a canadian XZ2 as well.
But I must say I'm a bit weary of doing this. I think the reason I have a functional phone with the botched new update was because my Oreo data was still on the device that the XZ2 could revert to.
Anyway, here goes.. Repair process has started.
Just as I expected, the phone is now softbricked.. it'll bootloop for 5-6 times, then display a message that the system is corrupt.
You did a full software repair using Xperia Companion or you just performed a factory reset?
I did Repair in Xperia Companion. After the process it rebooted, and did the bootloop then the System is Corrupt message.
I can't use the phone anymore.. are there any other options to at least get the phone running again?
Redo the software repair process, observe the process closely and make sure the download has a logical size (I'd say around 1.5GB) and there are no dropped steps.
I would say the update was at least 1gb as it took awhile to download on my fiber internet connection. I can't see file sizes during the repair process (at least this time when I tried again) and nothing is displayed on the phone screen.
