As stated in the title! When I used a certified quick charger with my phone, I do get a little orange light indicating that it is charging however on the lock screen there is no text saying that it is "quick charging" or "fast charging"... infact it doesn't even show the word "charging".. also the battery icon in the notification bar shows no indication of charging... But if I use a normal charger it does say that it is "charging"... Is this normal behaviour?
Hi @Monzur2101,
Glad to hear that you decided to get the Xperia XZ.
According to the information I have, even if you charge your Xperia device using a Quick Charger that is Quick Charge 2.0/3.0 compatible, the text "Charging" is displayed on the lock screen. The same text is displayed when you use a regular charger.
may I ask is the charger bought from sony? or a sony quick charger product? or is it a third party manufacturer?
also try to change to a default preinstalled theme, restart your device and see if there is an indication on the lockscreen of charging?
also try while you are in safe mode
Hi @Monzur2101,
What is the procedure to obtain a confirmation from the device that it is quick charging and at what level (2,3)?
@Monzur2101 I see your point and I can forward this as user feedback. Meanwhile, if you need to verify the charging current there are some apps that allows you to do this as @alexdon mentioned above.
