As stated in the title! When I used a certified quick charger with my phone, I do get a little orange light indicating that it is charging however on the lock screen there is no text saying that it is "quick charging" or "fast charging"... infact it doesn't even show the word "charging".. also the battery icon in the notification bar shows no indication of charging... But if I use a normal charger it does say that it is "charging"... Is this normal behaviour?
