I have been using the camera feature primarily for my princess, but the photo qualtity is not good especially in the night or indoor without enough light. (Comparing with Galaxy S7 and iPhone S6, XZ blure the details.)
I'm using 23MP(4:3) option and also used 8MP(4:3), but couldn't see the difference on the photo quality while many people told me the 8MP is better than 23MP.
Can you share me your option with the reason??
@Viridis wrote:
No, higher ISO adds some noise at various levels, higher shutter speed will make things blurry.
I agree with you and ISO will add noise as well as blury, so it is necessary to control the shutter speed even it is difficult to control the shutter speed with proper value...:)
Yes you are right and it is not possible to set up the iso and shutter speed simultaneously.
I toyed with several settings while I was photographing the ruins of Angkor. 20MP (16:9) works best for me. 16:9 mainly because I take landscape photos and want the extra width (4:3 crops out the sides a little) and 20MP because the 8MP setting blurs out edges when in bright sunlight (for example the edges of buildings against a bright sky).
For selfies, I use 4:3 at the highest MP for the extra height.
