Anyone having issues when rotating screen to view recently taken photos in landscape mode and yes I have the landscape mode enabled. It happens when I take a photo and try to view it in landscape mode but it won't so I have to disable & re-enable landscape just to have it working again. Hope Sony will fix it in future updates.
Hey @Kaiserjeff1986,
I'm sorry to hear that. For how long has it been like this? Does it happen every time you try to view a photo recently taken in landscape mode? Does the screen rotate when you open images in the Album app instead?
You can try and see if the same thing happens when your device is rebooted in to safe mode.
I would also recommend that you try to clear data for the camera app. Note that this doesn't erase any photos you have taken. To do so, go to: Settings > Apps > Camera > Storage > Clear data > Ok.
Let me know if this helps!
I see, was there any change after clearing data for the app or rebooting your phone to safe mode? Considering that it also happens with the Album app I would suggest that you clear data for that application as well, note that no images will be deleted by doing so.
Keep me posted!
