Hi @djp2k17,
I am sorry to hear about this.
Can I just check if you have tried all the troubleshooting here?: http://support.sonymobile.com/global-en/xperiaxz/faq/No-network-coverage/
If nothing in that troubleshooting has resolved the issue then it is more likely to be a hardware fault. Sending it off for repair is really the only thing left to do.
Most likely they charge a fee for no fault to pay for the time that the repair agent used to assess the device, along with postage. Warranty will differ from region to region though so you will be best to ask your Local support team that.
I'm selling mine as the signal is so poor on my commute. I get a couple of minutes weak signal on my iphone SE most mornings - the XZ drops out constantly during the journey. It's a definite and regrettable design flaw. I can cope with the less than stellar battery and the horrible processing of low light camera pics, but the low signal is a killer.
I have sent it off via Carphone Warehouse being where I bought it from & it's been "repaired" very quickly making me think that no fault has been found. I should hopefully get it back this week or next.
