Hello , i decided to lisen to my downloaded spotify playlist , with my MDR-1000X headhones , i can only lisen to the downloads , rather then stream due to there being a bug relating to bluetooth and 3rd party apps that sony are working on , fixing , frustrating to say the least , well ive discovered another frustrating bug , when my bluetooth is on , my wifi signal goes down , even thou its showing connected and has a good signal , i can only resolve this by switching of bluetooth , which makes my £329 bluetooth headphones redunant , regreting moving over from apple , come on sony sort this out
hello , it goes down like i cant access the internet on my browser or apps , but it shows up has having a good connection , once i switch the bluetooth off , it works , also i was using 2g not 5 has this is known to have problems , all my other devices worked fine , i had a iphone 6 and my blutooth and wifi worked when both conected , so i cant see it being interference
when bluetooth is on and wifi and nothing is connected , then i can use wifi , only when using a bluetooth device , wifi no longer works
