Since min 1 I've deactivated the vibration function. To save some battery. Yet after a month, i tried to activate it, and it won't come back ever since. Vibration works, as ive realized the tests. But in order of typing and long pressing actions it does not work. Already reset the mobile. Should i start from 0? Thanks.
Thanks for sharing this wonderful information.
Eso cuenta como una solución???? Gracias de todos modos, logicamente no sirvió de ayuda.
That counts as a solution ???? Thanks anyway, logically it didn't help.
gt
