Hi, I bought a UCH12W from the UK Sony website. I have just recieved it, however written on the plug it says it is a UCH12, without the 'W'. Please see pictures attached. The invoice says it is a UCH12 only. However the packaging says it is a UCH12W. Have I received the wrong item in the correctly labelled box? I'm very confused!
Thanks.
Hi @VBPS,
I'm sorry to hear that.
I would recommend that you get in contact with your Local support as can best assist you with this.
Did you seriously pay £40 for Sony charger when you could get Aukey that would do EXACTLY the same for £7.99 from Amazon and is the same if not better quality?!?!!??!
I'm using an aukey charger for the first time, but I have not noticed it charging my XZ any quicker than the UH20 charger that came with phone.
