Hello guys Does anybody here know of an external smartphone Telephoto lens suited for Xperia-XZ.? Is there anyone with experience in this area.? What are your suggestions. I am looking for at 20-30xmagnification.
those are a separate product and not accesories only, they work with any device inlcuding non-xperia products, other than those posted in the Sony electronics page, there is nothing else
there isn't one designed specifically for xperia devices, but you can google Telephoto lens for smartphones.
https://petapixel.com/2015/03/13/heres-an-80x-super-telephoto-lens-for-smartphones/
Hi there, that lens you suggested is not designed for Xperia products. I did find one that was reputedly compatible in Xperia z1 or z2 using a Carl Zeiss lens system. https://www.sony.co.uk/electronics/cyber-shot-compact-cameras/DSC-QX30. Does anybody here have personal experience with it.?
