Smart lock is missing on XZ1
RayRayRay
Visitor
The smart lock page appear empty, it was functional before but I noticed that location smart lock is not functioning.signal-2017-11-08-230820.png
 tried restarting the phone but nothing happened.
BTW, it's XZ1 dual.
Phone is updated.
There is someone here that posted the same problem but his post was marked as solved for the wrong reasons.
/t5/Xperia-XZ1/Smart-lock-is-missing-xz1-Bluetooth-issue/td-p/1273856
Please report this to the software department and thank them too for the awesome job they're doing so far.
Thanks in advance.
Tags (3)
12 REPLIES 12
androlool
Visitor
It's an oreo bug.
Go to settings> security >trust agents then disable smart lock. Reboot and enable smartlock again
RayRayRay
Visitor
Thanks for replying and sorry for the late reply.
I did your steps before posting the problem but that didn't help but the next day after posting here the loction smart lock start working again!!
And I also discovered another bug where the navigation buttons dissapear but still function in the software update menu
but it is not really a serious problem but worth reporting.
Thanks.
Daveilsanto
Visitor
Thank you! 🙂
profile.country.FR.title
hellionprime
Member
My XZ1 is a wonderful phone since day one, best phone ever. congrats folks
just a slight issue the smartlock option doesn't work  Slightly_frowning_Face under setting when I go to smartlock my pin is resqueted so far so good and right after that all I get is blanck page Slightly_frowning_Face the menu is empty.
any advice ? I don't want to reset my phone the for this
hellionprime
Member
sadly the new update with the last security patch didn't fix anything Slightly_frowning_Face
Sir_Carsten
Visitor
My navigation buttons disapered, had to reset the mobile.
ablrmn
Visitor
disimes95
Contributor
Hi @ablrmn
By what i read in this topic here in the forum, it´s a Android 8 bug, so try this:
1. Disable trusted agents on security settings
2. Restart phone
3. Enable security settings
Let me know how it goes Slightly_smiling_Face
ablrmn
Visitor
I worked with this solution and succeeded but if i restarts the phone it does not work again Thank you for your help
