Hello guys, how many of you are using the temperred glass cover on your unit. Did it have an impact on the speed your battery needs to be recharged..?
A screen protectot no matter if it is glass or a simple plastic one will have no impact on your battery consumption.......what makes you think this
I noticed after I put one recently, there was some reduction in my battery juice time. charging routine . that was the only change I did.
I read also from the web some users gave similar experience with other phone brands so I am asking if other xz users gave related experience..
charge the phone 100% > use the phone as you normally would for 2 or so hours > check the battery status > take screenshots
charge the phone 100% > boot in >>> safe mode > use it the same way as before for the same amount of time > check the battery status and take screenshots
same as before but this time w/o the screen protector.
As it had a screen protector on the display already . It's late to verify by peeling it off. I just wanted to know if somebody here had similar experience with their XZ. If they can confirm it really did, then I will remove it. BTW.. What kind of Gorilla glass does xz have..?
Thanks for your comments..
I have 2 Xperia XZ one with and one without a film protector, I don't see much of a difference.
Hmn. Good, waiting for other users to concur before I do further action.
BTW....
Huh.. You have to xz..,?
What for? If you have two phone sim numbers, you can have the the dual SIM for that.?
different situation, but we'll see if other users have similar situations, it will be helpful if you post the brand and model of the screen film/glass protector.
