Problems with flash
Gaturro
Visitor
Problems with flash
Problems with flash
Hola ...! Related to this problem, do you have a cell phone or a cellular cable, or a cellular or a car camera? Do you have a flash camera? Do not worry, do not you say it's normal and you're having trouble?
Problemas con el flash
Hola...! Tengo un pequeño problema al monto de cargar el celular, cuando conecto el cable de carga al celular y empieza a cargar, el Led de la cámara (flash) empieza a parpadear, no se si es normal o q puedo hacer si el problema persiste?
1 REPLY 1
profile.country.GB.title
Uliwooly
Expert
@Gaturro
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Boot in safe mode and see if you experience the same issue.
