Considering one of the phones strengths, the sound, it would be great to adjust the media volume more precise. Currently there are only 15 steps though. Could you please increase the steps for the next update to about 100? Should be easy thing to do since it is possible when rooting the phone (but I won't root unless you decide not to delete the ta partition with the drm key/s while unlocking the bootloader.)
Thank you
Agree! Between around 4/5 there is a huge jump in volume between too quiet to hear and too loud for my housemates.
There are apps that try to fix this but they don't work on the XA1.
Does Sony care?
Definitely! I agree. It will help a lot.
Thank you
This is a user based forum, you should send your feedback to Sony directly >>> Local support
