Ever since I updated my phone to Nougat, I constatly get "app x has crashed" and the phone keeps hanging and then resetting every once in a while. I reinstalled the software using Xperia Companion Repair, but nothing, I'm getting the same issue.
Anyone else experiencing this?
Ye I am also experiencing crashes and the phone runs sluggish all the time. I repaired using pc companion, for me marshmallow was way faster and performed a lot better.
@92@Vadim_BenKatz: I suggest you to perform software repair using Xperia Companion once more time, but this time do not restore your backup, just observe the phone if the problems occurs,,
you might be expriencing crashes and lags because one or more of your apps are not optimised yet for nougat update,
if the problem is gone, then I suggest you make sure to check each of your apps restored to see which ones are causing the problem
@92, you are using XZ right? as far as I know, Xperia Keyboard isn't available anymore for XZ, that is why it shipped with swiftkey keyboard.
