How can i remove the notification of android about 'lifeblog is working background'
@MNBRG now I understand. To remove that, do the same steps as I explained before (press longer on the notification). Then, select all categories. Scroll down to apps running in background and set the importance to low.
Yes im using lifeblog is there any solution?
@MNBRG drag down the notification bar, tap longer on the lifelog message, select more settings and turn off notifications. I am afraid this will block all the notifications from lifelog but will also remove it from the top screen.
Thanks i closed notifications about lifeblog but lifeblog isn't my problem. Android system notification is still there(about background apps)
Notification cant come down....
