Xperia XZ after FOTA to 39.2.A.0.442 discharges battery during 8 hours to 0% even if it is not used.
A reason is media.extractor process which is running all the time in backgound. As it can be seen in adb shell:
User 29%, System 2%, IOW 0%, IRQ 0%
User 34 + Nice 325 + Sys 25 + Idle 833 + IOW 0 + IRQ 3 + SIRQ 1 = 1221
PID USER PR NI CPU% S #THR VSS RSS PCY Name
2396 mediaex 31 11 25% R 5 53852K 4364K bg media.extractor
13010 u0_a291 30 10 2% S 31 1084944K 90032K bg pl.solidexplorer2
669 system 12 -8 1% S 16 147952K 9828K fg /system/bin/surfaceflinger
10266 u0_a225 16 -4 0% S 85 2051104K 136208K bg com.cnn.mobile.android.phone
13866 shell 20 0 0% R 1 9116K 2200K fg top
13376 root 20 0 0% S 1 0K 0K fg kworker/u8:10
14457 root 20 0 0% S 1 0K 0K fg kworker/u8:12
3225 u0_a190 20 0 0% S 21 1716936K 74628K bg com.touchtype.swiftkey
389 root 20 0 0% D 1 0K 0K fg msm-core:sampli
4585 system 20 0 0% S 12 1585184K 36924K bg com.sonymobile.phoneusage
3809 root RT 0 0% S 1 0K 0K fg irq/19-408000.q
2369 root 0 -20 0% S 86 116036K 1084K fg /system/vendor/bin/thermal-engine
7 root 20 0 0% S 1 0K 0K fg rcu_preempt
3 root 20 0 0% S 1 0K 0K fg ksoftirqd/0
2845 system 18 -2 0% S 191 2612088K 275872K fg system_server
I have not figured out yet if any particular media file causes it, anyway this is new behavior, definitely this is a degrade compare to previos FW.
Hi Cristofer,
Since the recent Android update to 7.1.1., my Xperia XZ's battery life has been almost cut in half. My usage has not changed.
Prior to the update, I would comfortably have 20+ hours battery on a full charge, now it is around 10 hours. Why is this, and how do I get my battery back to what it was?
Furthermore, the phone gets quite warm with normal usage.
So, since the update:
1) Battery life cut in half
2) Phone is constantly warm
I have repaired the device/factory reset 5 times, erased the SD card, tried with no SD card - still to no avail.
What can you advise?
Regards,
David.
After another factory reset the temperature seems to have stabilised. Further, the most recent update from a couple of days ago seems to have helped slightly. I'm actually following the advice by Emir written in his article here: /t5/FAQ/Improving-Battery-time-and-battery-enhancement-features/m-p/1217684#U1217684 So apparently after a reset the phone battery calibration requires around a week to stabilise. I'll wait for that time to lapse and monitor in the meantime.
@davjac7 Thanks for letting me know! Don't hesitate to get back to me if you should have any further questions about this.
