Translation via Google Translate:
How do I change "shell" on keyboard?
Hvordan skifter jeg "skall" på tastatur?
English please
Here is an example of how to translate your question.
That being said: could you explain a bit more what you're asking?
You mean shell in a command window/terminal or something?
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
If you meant how to change the "skin" of your keyboard, then this will depend on which keyboard app you're using. Try to find the "Settings" key on your keyboard and you might find some options for customization inside.
Hi @BjørnFerry, welcome to our forum!
As @Quester mentioned, your question has been translated to English as this is an International forum.
To change the theme on the Swiftkey keyboard, go to Settings > System > Language & Input > On-screen keyboard > Swiftkey > Themes. Here you can choose between different themes and you can add a picture from the device to have as a "background" on the keyboard.
I hope that helps!
