Is this normal? 31% battery drain on phone idle??
Hi @isbesheer,
Seems like something is keeping your phone awake. Does it do the same in safe mode?
How to access safe mode?
@isbesheer wrote:How to access safe mode?
First press shut down hardware button when power menu pop-up then press and hold "Power Off"
after a few seconds you see a new pop-up say "reboot to safe mode"
select Ok... Your device power off, after booting you are in safe mode.
For boot to normal mode, only reboot your phone normally.
