Hi @Pallemans,
I am not sure exactly what you mean... The screen bounces a little when it tries to read a fingerprint and fails. When it bounces, do you see at the bottom something that says "Not Recognised" or "Finger moved too fast"?
If you have the fingerprint scanner enabled it will always try to read it. It will always "bounce" when it does this. You will have to turn off fingerprint recognition to stop it.
