having just upgraded to a XZ there is one thing thats annoying me,how or can you get rid of the google feed icon on the home screen so you can actually set the homescreen to one you want
Long-press on any empty space on your screen -> Settings -> Disable "Google Feed"
You can enjoy your new device even more if you read a bit.
F.i. if you scroll to the bottom of this screen tap or click on Smartphone Photography or follow this link.
You will be rewarded with a better user experience after you do some reading.
Enjoy!
where in all that reading does it tell you exactly what to do,it obviously does'nt otherwise forums and youtube help video's would not be out there,
