Hi @simon435500,
Welcome to the community!
I'm afraid that there currently is not possible to add more than 20 alarms in the preinstalled app. I can however forward this as user feedback if you'd like.
But as @NeoBeum mentioned, a good way work around this is to set multiple repeated daily events in the calendar instead of alarms.
Let me know if there's anything else!
@NeoBeum
OK, I will try that.
Thanks for your help!
@Didrik
OK, please forward this to user feedback.
There is another question that I cannot find user feedback function of pre-installed app.
As far as I know there isn't a feedback function directly in the app. If there is anything else you are wondering about, let me know!
