Hi @waibb, welcome to the community.
@Viridis is correct! It is indeed waterproof. There is a waterproof membrane that keeps it water tight. The same membrane is in the charging port.
If you do get water in it, make sure you shake it out and let it dry before you try connecting any headphones or charger.
