Hello guys.. Normally what is the boot up time of the xz if you had not changed the apps content. I found mine to be more than a minute... reaching 1,minute 15. Seconds..
Mine goes maybe just under the minute mark. Are you already on the nougat version? The are reports that the boot times is significantly faster on nougat update
It's faster on Nougat but not by much. Never understood why it matters tbh, i use the phone when already booted, at that point it's one of the fastest available
It's the internal memory. SONY uses the old style, cheap eMMC which is much slower than the memory used by Samsung and Apple etc. When you boot your phone it loads the o/s from the internal memory and the read speeds are much slower on the XZ than the Galaxy.
I have used a debloater tool from serajr on xda.its for non rooted X devices and locked BL only.My bootime is just less then 40sec.also battery life improved a bit. On the other side pc companion not find my device anymore. But not needed if you can still get OTA update tru phone instead of PC.
Don82 I am wary of using third party apps thatdoes not belong to Google play approved tools. For me its enough to know that my boot up time was improved by recent updates. I just only want to know of from similar users how much improvement they got after they updated their XZ To nougat...
