Bought one week ago my xz2 compact. It's a good phone but my battery is killing me. Charged him last night at 7:30 he was full now its 9:40 and he's almost empty without using him
Sorry for my bad english
Grte kevin
I have the same problem, that's a big problem. I use to close all the app after every session but nothing change
Go into the apps in settings, then go down the installed apps and dissable and force stop everything you dont use. If you dont recognise the app dont touch it without checking what it does first. Facebook seemed to want to run in the background on mine even though I dont use it.
That worked for me, also you can go into settings-battery and see what is eating up your %
