Just me or is fingerprint unlock really slow since update to Pie? Sony Xz2.
Also, not sure but battery life also seems reduced.
@TripleAK @MechanicalDope @Usguyver
Did anyone try removing all the stored fingerprints and register new ones? Just for the sake of troubleshooting.
I am getting the same fingerprint that has me a little bit slower but battery life is been phenomenal for me on Android 9. But I have noticed it being a little bit slower to unlock.
Me too. Finger unlock is slowly
@Quester wrote:@TripleAK @MechanicalDope @Usguyver
Just tried. Has definitely helped. I am going to accept this as the solution. Good suggestion, thanks.
Tried and work better.
Thanks
Didn't work for me, I tried a factory reset and it's still much slower than the previous OS version.
I've got a solution. The fingerprint sensor works better now. I did the following. Go to Settings > Apps and Notifications > Advanced > Special App access > Power-saving feature and open it. Then choose: Not optimized change to: All Apps. Type in the search field in the top right. Write the Word finger and search for com.sonymobile assistant.overlay.fingerprint. Make sure that is selected: Don't optimized then search for FingerprintExtensionService. Make sure that is selected: Don't optimized. It should say excepted for both. It works well for me. Please let me know what you have experience with it
It worked for me
