Hi @fetch93,
Thank you very much for the feedback.
I can understand the comments regarding the data enabled and disabled, however, these do help the user understand what is currently running on their device, and as the internet is one of the most important parts of a smartphone, it is always good to know when the service is on or off.
Again thanks for the feedback.
Hi @fetch93,
