Rolling out right now. thanks Sony
Pixel phones got 7.1.1 today and yet some of us are still waiting for 7.0
Will Sony be rolling out 7.1.1 at some point soon, or is 7.0 the best we can hope for?
camera software also needs a fundamental update as it takes blurry photos..
I've read all the forums including Sony XZ Xda ..... Please pass this to the Sony team for 7.1.1 or any future updates
1) Low Speaker volume - ( please increase the speaker volume)
2)Camera - Post processing not upto the mark , It gives a feeling RGB n IR sensors are not properly utilisted
3) Priority mode to keep certain apps running in the background just like Samsung
4)Stamina Mode - It makes the phone sluggish ..need to improve when it is on Balanced mode
5)Switching sims reboots phone ? - Sony its 2k16 😕
I would really like to see improvements in these fields
This is a user based forum, don't forget to send your feedback to Sony >>> Local support
I don't know why are they keep messing around with that Head Up notification?! They fixed it on Marshmallow and now on Nougat it's the same! Whatsapp perhaps, messages keeps pops up even if they are turned off in the app settings. You have 3 options: show only wapp sign in the notification bar, turn them off completely or turn everything on. Neither one is good for me. On the other side, on Viber you can get the sound and notification icon only. So annoying
