Got the system update yesterday. This morning the snooze function in the alarm clock is all over the place. I've set snooze duration to 5 minutes but it restarts the alarm anywhere between 10 seconds and 2 minutes from snoozing.
I alse turned off an alarm that was snoozed in the clock app but it rang anyway until I swiped the dismiss bar when it rang again. This was also ahead of the set snooze duration.
Has anyone tried resetting their phone? I'm about to do this, but don't want to if it's not going to work.
Same problem here, Android 10, H9436, 52.1.A.0.532.
Did you try the reset? Did it work?
Nothing works!
Has anyone found a solution for this???
I never had your version of software. I just got finally an update to 52.1.A.0.618. Your problem was fixed! Now alarms are not ringing at all. Great job! Please fix.
