Hi, Is this update only for XZ single sim? I have a dual sim version and, I did not get any update for February.
Is the drop down bar bug fixed?
It started to disapear when i updated a few weeks back to version 39.2.A.0.386.
(Example of the bug)
This also happened to me and I'm on Marshmallow. I believe it has to do with the newest update to the Google app and the Xperia Home launcher. It was also asked and solved in another thread, please see:
On Google+ Xperia™ Home Open Beta Communitie Sony said they are working on fix.
For now disabling Google Now™ pane only works.
