the issue with the time/date reset has been also fixed,,,
Glad to hear of so many improvements! Battery life as the "Phone Idle" issue is solved?
I wonder if this is happening to all users who are on Nougat or if it's only to Xperia users on Nougat. Would you able to share a screenshot of your battery usage, please?
Camera still same because its still version 2.0.0 in every udate till now. There you will notice when the camera would have any improvement.if its my greenify app or not, phone idle drain dont affect me from MM to N. I can go easy for full day and still got 40 to 70% on my usage.depend on my usage all day. Idle means phone in stand by. When i go to sleep 100%,in the morning i still got attleast 97% over 7hrs to 8hrs. I browse many times,snap pictures,video's, phonecalls and thats what i got today after 22hrs.I can say for the 2900mah its doing just enough in batterylife personal.
Battery is a little better now but still not like on Android 6.0.1.
And yes. They finaly fix double tap to wake.
Android is working mouch better.
Only thing is that after latest Google app update status bar is not working correctly. Sometimes on homescreen status bar is missing and sometimes when status bar is working on homescreen it is showen in app tray too. Uninstalling Google app update or disabling Google now pane fix this for now. This is on officiale XPERIA Home 10.2.A.1.15 version. And latest beta version 10.2.A.2.10 has the same problem. Sony said they are working on fix.
I have a friend who has a Google Pixel XL and asked if he could send me a screenshot of his battery usage to see if maybe the high Phone idle percentage was a part of Nougat or a bug in Xperia's Nougat update. As you can see, Phone idle is only at 2%! I wonder if it's because he's already on 7.1 Nougat.
