help me plzz...i just bought this phone few days ago...i'm about to give up..
Go to settings> basic settings> settings download and wait for sometime for the settings to get downloaded.
If it doesn't help, contact your service provider to get the correct internet settings and apply for a data plan from them.
hi...thanks for the info..but i already try that..but it doesnt solve the problem..i can send mms and login to facebook with 3g connection and wifi..but when it comes to creating a google account,it says
'Can't establish a reliable data connection to the server.This could be a temporary problem or your SIM card may not be provisioned for data services"...really hope somenone could come with a solution..i can can create google account at first with the same simcard but after i did a hard reset,this problem occur..
"Can't establish a reliable data connection to the server.This could be a temporary problem or your SIM card may not be provisioned for data services"
just for this part:
- turn phone off
- take out simcard
- turn on phone
- reset to factory settings
- turn on wifi (put in your own wifi settings)
- turn off phone
- put simcard back in
- turn on phone
- follow the initial setup to sync with google account
then you should able to sync with google
but i can't get the 3g working either... i live in canada
and the phone i have is international version so it's not 'compatible'
sigh... -___-
thanks!...it works!..i can create google account now and i can access to android market...thank u so much for your help my friend!..:smileyhappy:
