Help with music in W100
Not applicable
Hey guys, i need a little help over here. So, I bought one Sony Ericsson W100 and i've transfered some musics to my memory card. However, some musics are having problems, in other words, they don't play. I checked the files, all of then are .mp3, but it isn't the problem, once i tried other .mp3 that worked. If I 'put' this music that doesn't play at walkman, as ringtone and call my cellphone, it plays! I tried rename the files and another memory card, but i got nothing. (Sorry for my english, i am brazilian)
7 REPLIES 7
Dr_Chris
Champion
http://www.sonycreativesoftware.com/products/mediago/default_enu.asp Follow this link to download Media Go for your phone and use it to transfer music files between PC and phone.If the music is already in your phone, transfer it back to your PC and re-transfer back to the phone via Media Go.
Not applicable
Hey Dr_Chris, thanks for replying. So, I already tried the media go, i erased all the musics and used this program to transfer, and i got nothing again. I thought about update the celphone's software, but i am afraid cause if it didn't work, i lose the warranty.
Thanks for the help.
Dr_Chris
Champion
Updating the software will not void the warranty.If Media Go doesn't work after a software update, you can try something like Switch, an audio file format converter which you can download to your PC, use it to convert file formats and then transfer the converted music files back to your phone.
Not applicable
So, are u sure it won't void the warranty? Then I will try it. I will download a converter, but as i said, it was .mp3, it should work right?
Thank you very much.
Dr_Chris
Champion
As long as it's software from SE, it will not void your warranty---who told you this anyway? There are different codec sub-types of .mp3 formats, so I suggest you use the converter to switch to AAC or .mp4/m4u, which are supposedly improved format versions of the .mp3
Not applicable
Friends of mine told that, but I will update it anyway. I will convert then. I reply as soon as I get a result. Thank you very much!
Not applicable
Hey, so I did not update the software, however, I tried converting the .mp3 files. It WORKED! I've converted .mp3 to .m4a and it worked! Thank you very much Dr_Chris.
Best Regards,
Giovanni
