Hi, when I say "ok google set timer, she asks 'how long?' I say "20 minutes", the timer has been set. I decide to cancel the timer manually (lets say after 10 minutes), the timer has been stopped (well I though it has...). But the initial timer (set for 20 minutes at the beginning via voice command) is still going till 20 minutes is up. I then have to manually stop the timer again. I've restarted the phone, same outcome - the timer won't stop if it has been set via voice command. When set manually, works fine. Please fix this minor annoyance. I am using the latest software kernal version "3.4.0-perf-gc14c2d5BuildUser@BuildHost" Android version 6.0.1 Thanks.
I thought the timers were independent, one with your phone and one with your SW3, I'll do some testing
The timer only started on my SW3 not my phone
The same problem is on my Z5 actually.
