i bought an MW-600 to work with Xperia X10. But it seems to be missing Track ID, Caller Name display (Caller's number is displayed) and Seeking within the same track (Forwarding).
Why do SE advertise as combatible while it is not really compatible?
How do we get this working?
I seem to have the same problem, i.e. forward and reverse buttons does not work as expected and play/paus does not work either. the MW600 is working fine though together with my previous SE-phone (Z710i). Most annoying. I have tried to reset both my X10 and the MW600 several times without any changed result
It just does not work - HELP!
I posted this already, before I saw the Xperia specific forum. I guess this place is more appropriate.
I have problems using MW600 and WiFi at the same time. Any time I enable Bluetooth + WiFi on my X10, audio starts skipping and MW600 usually loses connection altogether. I tried resetting MW600 several times, but the problem returns. Surely it should be possible to listen to music and browse the web at the same time? Any advice? Is one of my devices faulty?
The Play/Pause button works.
However sometimes it seems like the first pressing only wakes up the headset from some sort of sleep. (Haven't checked the Forward and Back buttons though.)
Also, the headset may not be associated with the media player you are using for the moment. E.g the player MortPlayer has a setting for headset behaviour.
Not sure whether SE has missed out this or purposely they are skipping this thread.
