I have just got my new x10, and i would like to forward texts that others send me but i cannt figure out how to. Can any1 help pls
Hi waveydavey101,
I had the same problem yesterday.
What you have to do is press down on the text for a few seconds that you want to foward. You should then get various options and forward is one of them.
Kind Regards.
I suggest x10 owners to us Handcent Sms, it's really give you many more options for messaging, better than original android messaging apps.
Anyone here use android onscreen keyboard??? I find that android keyboard is much easier to type compared to SE keyboard.
Yes, I use the Android keyboard, rather than the Sony Ericsson one. I was going to load something else so I could use T9 for text messages, but the Android keyboard isn't bad at all, so I didn't bother.
For those who want to try it out, you get to it in the same way that you'd change the phone from the Japanese input screen - go to type a message, press and hold the white text box, and when the options menu comes up, select input method and then Android keyboard. And just do the same to get it back to the Standard (SE) or Japanese keyboards, if you want.
