re:couldn't use bluetooth
Not applicable
hi there,
may i know why does my xperia x10 couldn't use its bluetooth?my xperia x10 is using 1.6 software.can anybody help me regarding this issue?thanks.....
1 REPLY 1
suze
Leader
Hello there, can I suggest you have a browse through the following thread which may give you the advice you require.
http://talk.sonyericsson.com/thread/4503?tstart=0
I hope it helps but if you have any further problems, please ask.
