Phone Lock
Not applicable
Phone Lock
How I can Lock the phone? , I'v bought two SE phones Elm and Hazel and
2 REPLIES 2
KrazyD
Contributor
I don't exactly mean what you mean by lock as it's a bit vague but I will give you an explanation on them all.
First if you want to lock your keypad on the main screen press * and then unlock when it appears.
Second if you want a phone lock code which will appear everytime you turn the phone on go to Menu - Settings - General - Security and set a phone lock code in there.
Hope this helps.
Not applicable
There is no pgone lock option under main menu, settings, general, security. And pressing * to lock the keypad doesent work also, not with Hazel.
