I have an ELM J10i2. I find conversations nothing but a pain and lose messages. is there anyway i can just view messages the regular way through inbox and delete or disable the conversations?
Hi, On your phone go to Menu - Messaging and then click conversations second one down. Now click left to get back to the normal messaging tab.
yeah, I know how to swap between Conversations and Inbox, I appreciate your help but that isn't what I'm asking, problem is my messages don't go to my inbox, they automatically go to and get lost in Conversations, I want to delete conversations, it's nothing but a pain.
so I'll ask again
Conversations, how do i delete or switch it off?
There isn't anway to remove or switch it off.
Thanks for that, much appreciated, I spent a lot of time and effort trying to switch it off, I guess I need to buy a new phone.
you can try to switch first from conversations tab to inbox tab. then the next time a new message comes, it will then be read as a normal message and not as a part of the threaded conversations.
