Hello
I can't send or receive MMS.
In my mms settings it's on automatic mode for downloading.
If I turn Wi-Fi on it doesn't work.
Any ideas on what doesn't work?
Thank you for any help
Also i tried to send mms in safe mode.... I Don't manage to send....
Hello again!
While you are waiting to get a hold of another SIM card in the same size as you have you could try sending a MMS from a different application to see if you are able to do that for example, Google messenger that you can download from Google Play store.
If you live close to a store that your service provider have, or a store that sells phones with your service provider you should be able to go there and ask for a new SIM card.
Good luck with finding a SIM card that fits in your phone and have a nice Thursday!
Hello
I can send picture with whatsapp !!!!
Sim card change seems the next moove to try....
Hello again!
When you send photos or files with Whatsapp you aren't using the MMS feature that your network provider provides so that is why that is working and not MMS messages.
Let us know how it works with a new or different SIM-card!
