Cant use stamina on with whatsapp. Cant get notification at all. Only when open whatsapp, little delay and message comes.
If not use stamina. All works just fine. So problem is stamina battery saver program? and closed services ?
Whatsapp notifications all are ON.
-I am closed a lot services on application list. Mayby i close wrong one?
-Cant know what services/programs need be on and what permission must put on again.
-I dont want do factory reset.
Any clue?
Yes.
and by the way. I love my XA. Beatufylly design and working fine expect whatsapp.
i hihly suggest @Roadrunny76 idea,. you can try to add the app to the battery optimasation list and restart your device. take note that it might not be the stamina mode that is restricting the app but also the Doze mode by google. try to contact the app developer for more help
If dont use stamina mode. All works fine. I quess it depends somehow on stamina mode?
Restart several times. How do "deeper" restart not just normal?
I closed severall programms and take permissions away of them. Mayby there is something closed.
Anyone knows what programms and permission Stamina needs to works with "tree dott" whatsapp. (Giving all permission on whatsapp with stamina mode.)
I don't know if this is availble on XA, but can you adjust the stamina level?
have you tried to reinstall the whatsapp app? or install an older version.,
I think you should contact the app developer and report that you are having a incompatibilty with your device, they might issue an update if this is a widespread problem
How i make sure that my data connection isn´t sleep?
